How to confirm if you have Tach signal
Post helpfull How to's for other from your hard work and experience!
User avatar
12volt Does it
by 12volt Does it » Fri Mar 08, 2024 9:50 pm
Set the meter to AC voltage. Connect the negative Meter lead to a good chassis ground in the vehicle and the positive lead to the suspected tachometer wire. Start the vehicle and wait for it to idle down to normal idle speed. At this point the meter should be displaying a fairly constant AC voltage.
Who is online
Users browsing this forum: No registered users and 1 guest
It is currently Thu Nov 19, 2026 1:20 am
