Page 1 of 1
How to confirm if you have Tach signal
Posted: Fri Mar 08, 2024 9:50 pm
by 12volt Does it
Set the meter to AC voltage. Connect the negative Meter lead to a good chassis ground in the vehicle and the positive lead to the suspected tachometer wire. Start the vehicle and wait for it to idle down to normal idle speed. At this point the meter should be displaying a fairly constant AC voltage.
